DollyRocket
My 1150GS 2003 twinspark with servo & ABS has performed a fancy trick on me during the last two wet days (one of them being today) and dropping out the Servo with the 4Hz blinking ABS light and Gen light on indicating that residual braking is active in both circuits.
Curiously, it has done this twice now, both times when i was slowing down from the motorway on a sliproad, when I do manage to stop the system resets itself and powered servo assist braking is restored. (no stopping engine or ignition off resets required).
The only thing I have done recently was to remove the front wheel and abs sensor to paint the fork legs, bolted it all back on and everything has worked fine until last week. if I had damaged the abs sensor on the front wheel I would expect the servo to still run and just knock out the ABS and even that would only be on the front wheel (i.e. ABS light flash @ 1Hz and no Gen light).
The brake light bulb appears OK, but i will change it to be sure - don't think this would affect the servo though (according to the other threads).
Do you think this is an impending sign that the Servo is about to give up? The bike is regularly St. eptoe'd, last one 3000 miles ago. I take it that know-one knows of a remanufacturer of the servo's?
I quite like the servo and would loath to get rid of it but any advice gratefully received.
Mike
Mike
turned out to be the rear brake light switch dammed stupid system
