RID issues
haydw
Preston, England
All I have done is change a battery. Am at a loss.
Before the battery change everything worked. I have HIDs but have had them for years with no issues.
My fuel gauge won't work and my temp gauge when warm has two bars and third flashing. Gear position works. That's until I have just had another fiddle.
Have checked the RID multi plug, no corrosion,nothing loose. The RID indicates 0 for neutral, but won't display any other gear. If I remove fuse 1 it does work. As soon as I put it back, it won't.
Aaaaarrrgggghhhh.
Collective wisdom?
Your solution is to move the HID ballast further away from the RID. I had the same problem and after I did this I never had an issue.
