Yogibear69
My 2018 1200 GSA rally has 31.5mm bars
Ok so the GS 1250 HAS the same then
Fixed............![]()
just discovered they wont fit because the cables are too short. Has anyone fitted a set of these risers to their 1250 ? If you have how was the fit ?
Just buy Rox and be done with it![]()
IIRC the Rox fitting instructions say that the hoses may have to be moved/adjusted but I didn't have to do that with mine![]()
Look at post 14, mine are setup that way on my 1200 2017 no problems at all with the cables.
Rox risers or smaller Wunderlich ones
1250?
No 1200, but I think you are looking in to this too deeply![]()
Possibly but i dont want to buy anything that wont fit
You might have to adjust the front brake and clutch hose or you might not
Are we happy that the handlebars are the same thickness ?
Now that ive found a set of Rox risers that are 32 mm yes im happy. Still need to confirm ROX 2in risers will fit. Happy that the others will fit though.
I fitted these risers (Rox copy) to my 1250 without any issues, and they are British made (Moto CNC)
https://www.ebay.co.uk/itm/BMW-R1200GS-2013-Onwards-2-Bar-Risers-For-32mm-Bars-Made-In-The-UK/223473033276?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
They are 2" risers but you will have to reroute the brake lines and cables. Its fairly easy to do and takes about 10-15 minutes.
You can download the Rox risers rerouting instructings in the link below.
https://cdn.shopify.com/s/files/1/0735/5123/t/2/assets/bmw-reroute.pdf
The 1200LC and 1250 models have the same diameter bars. The pre-LC has 28mm bars.
I fitted rox risers to my one time GSA Hexhead and had to re route the clutch cable but it was easy to do. I will take a look at these you bought. Cheers
