Route Plotted In Basecamp
Mr Bean
Goffs Oak
I seem to recall a post on how to stop the Nav V trying to take you back to a missed junction - even though you have corrected the error and are now back to the intended route. I made a few plotting errors earlier and it wouldn't accept I was on the right route as I had skipped the errors.
Can someone pls point me to the post or info?
Thanks in advance.
Assuming you want to do this on your device on the go, the device has a skip button.
If you are creating your own routes, you can convert waypoints into unannounced shaping points, which the device will not you back through should you miss one or more out.
I'm learning how to create my own routes.
Thanks for the help.
you can also use the controls wheel
press it
scroll down to where it says skip and press it again
point skipped
simple
