Routing for fuel breather and vent?
Magwych
La Salvetat Peyrales, Aveyron, FRANCE
As the rebuild of my 08 GSA lumbers along, I have hit a memory issue withe the fuel tank pipes.
On each side there are rubber pipes running down to just behind the gearbox. One is the overflow, the other is the vent for the tank.
As it came apart I remember that these were not routed through their correct holders, but I do not recall the correct routenor which holders ate required to route them "properly".
I know I can just tie them to the rear frame, and let them dangle behind the 'box; I do have the correct holders, so may as well use them.
Does anyone know the correct route and mounting points for their holders?
I took loads of pictures before stripping everything down, and can see the black rubber hoses amongst the bkack wiring and black frame; and can see that they were not routed properly after a service or clutch change. That is what I hate about paying someone else to do a job, I always find the bits that they did not finish as I would wish....
So, any chance of some piccies off a similar, unmutilated bike? It is the lower section of each tube that I need to sort out.
Left side,
Right side,
The pipe is the one in the centre,
Both pipes run in grooves on the out side top of the tank so no need to take the tank off.
You do have to take the painted cover panels off though.
