Rt Speakers
busy builder
Cromarty
If I turn the 'wheel' it says speakers turned off, but I don't know how to turn them on how do I get the speakers to work ?
Sometimes the available options are off the screen and need to scroll up or down to see them.
Some of them are scroll right to bring up sub menu.
Does this schematic type explanation of the menus help at all?
When I select AUDIO I don't get loudspeaker or Bass Treble option, from memory I only get BT PAIR ?
Press the Menu button 6 times.
scroll all the way up to Audio
Select it
scroll all the way up to Loudspeaker.
Select it
Scroll up or down to select speaker on or off..
If the current menu has a little arrow at the top or bottom, then there are more options to be found.
I'm a plonker !
I scrolled UP and lo and behold there it is. Thanks all.
