Rubber bugs
Doc
Ey Up
Slawit
Hi lads,
I'm wanting to higher my screen a bit and need to fill these holes with a bung of some sort. I only need three if someone has any please. Or ill buy some from somewhere.
cheers Doc
Hi lads,
cheers Doc
Is a hole a 10mm in diameter exactly?
If so I do indeed have black plastic caps.
No as they are not exactly round that's why something rubber might be better. 20240310_093912.jpg
In that case, I can not help you with the supply. Soz
Something like this might work, but I suspect that the Perspex is a bit thicker than a slot wide on the rubber blanking grommet
