Interesting – thanks for the heads up
Bike rarely ran below 3000 rpm which is where I believe the ECU switches from open loop to closed loop fuelling (or vice versa - wtf that means
). I’ve ordered a used replacement lamda from Motorworks today (lost the original – don’t ask!). I don’t think it can do any harm re-fitting it
I've also got a K1200RS fuel pressure regulator fitted which runs at 3.5 bar as opposed to the 3.0 bar standard fuel pressure regulator. I used to have a PCIII fitted which lasted all of 1000 miles before self destructing
I suspect that the bike is indeed running rich as a result of the fuel pressure regulator and current lack of custom map. Which is resulting in the end cans destroying themselves on a regular basis
I should be picking up a Remus Y piece and Can on Saturday to replace the blown laser hot cam fully system. I think I’ll look into ECU re-mapping to hopefully stop this happening again. Total cost for running repairs to current system are in access of 1K
