Scottoil
Hi Sue,
I used to have a F650 funduro (the predesessor to your GS) and I had a scottoiler fitted, they are excellent.
It does take a while to fit a scotoiler but only 1-1.5 hours if you don't know where to fit the vacum hose until you take the tank off. All the rest is fairly easy.
As your bike is fuel injected (and mine wasn't) I dont know where to fit the vacum hose, but I know it can be done as I have seen them fitted to the F650 GS.
It will not be difficult to fit, If you are mechanicaly minded you could fit it yourself, or get a local bike garage to fit the vacum hose, the rest is easy, all you need is cable ties.
Dont fit the Metering resevoir near the exhaust as it will melt, as i found out
If you ring Scottoiler they will find out where to fit the vacum hose to your bike, I have called them in the past, they are pretty good.
In the mean time oil your chain with a brush and ride it
Regards
Andy
