Screen glare / reflection problems....
Robbi
Bangor NI
Evening all.
I've recently fitted a perspex headlight protector and I'm suffering from reflected glare back and up onto the screen, is there a peak type thing that can be fitted to eliminate this, it's very off-putting.
Do you know how Perspex reflexs light ? ... you need a narrow strip of black tape along the “thickness” edge at the top of the Perspex
Ah, OK, so the light basically comes out of the top edge of the perspex. That's great, many thanks indeed.
Robbi
Evening all.
I had the same on mine with the hid in low beam. I used some double sided tape and a piece of thin plastic about an inch wide. Just taped it to the curves on the top of the headlight with it almost touching the protector. It helped a lot. I now have the led conversion and because the low beam is on the other side it's worse because the glare is not hidden behind the rev counter anymore. . I've cable tied a piece of old inner tube hanging from the adventure cross brace which has stopped the glare. Doesn't look that good but it does the job.
Think I might have to do some innovative thinking as Steptoe's tip didn't work.
Going to look at the eyebrow idea above over the weekend
Many thanks chaps
My advice would be to dump the OEM headlamp unit entirely and buy an led unit instead. Chalk and cheese. You'll never look back and you'll wonder how the OEM unit ever passed any regulation!
Plenty of info on here about the led units.
Screen glare
Got this anti glare attachment fitted to my bike, it’s made by touratech but don’t think it’s available anymore.
€120-150
And it's worth it
You still get the glare from the perspex protector. As I said above its actually worse with the LED unit because the low beam is no longer hidden behind the rev counter.
