Sertao wiring diagram wanted
MickDB1
Chesterfield Derbyshire
Does anyone have access or a link to a wiring diagram for the sertao or a late Dakar please. I have had a problem with the front brake lever switch to the brake light. I have tested the micro switch, which is good but cant get continuity between that and the rear lightbulb. I wonder does the signal feed anything else. Thanks if yer have thoughts or ideas. I have run a seperate wire from switch to bulb meantime as a bodge.
:thumby:
I can't find anything Mike, does your's have abs?
The abs has been removed from Ange's Sertao and I've fitted a Honda CRF 450 master cylinder to match the caliper. I had to use a pressure switch instead of the normal micro switch and there were no problems with the brake light, so you may have a broken wire or bad connection somewhere along the way :beerjug:
Thanks for the reply Tim. I too think that a wire is not continually connected. I found chaffed wires under the rear subframe above petrol tank on LHS which was rubbed with the help of the nearside sub-frame torx retaining bolt coming slightly loose. I have sorted all that out but I wondered if I could have blown something else while trying other fuses as I sorted the exposed wire. I have done 150mls today and locked up/set rear abs off. The ABS light does stop flashing on movement above 6mph as it should. I will find gravel and try to lock up the front to test that end of the braking. Just check the rear sub frame to main frame (8mm bolt) Mine moved only 2mm max. Off to Portugal in a couple of weeks and dont want problems.
HTHY back :thumb2
First class help Gents and thanks again. I will get on it tomorra.
Top blokes Top site
Well chuffed to be on here :thumby:
