Service done
SURMANATOR
Guildford uk
Just had the 12k andd anual service done at Vines of Guldford. Had an issue with brake judder ,new front discs fitted under warranty (no new pads tho) Brakes fine now. Total cost Including £25 for a loan bike! £342.46 Any coments?
:cool:
Happy for you :thumb2
No doubt some other bods will come along though and either say you should have done it yourself or that their mate in Aberdeen got his done by Wee Jimmy for £26 and a bag of chips..... or that BuMW in Portsmouth don't charge for loan bikes... or that the pads should have been done, too, as they will have chamfered themselves to the shape of your old disks and now you will die....
Absolutely - I'd have persuaded them into changing the pads as well. In fact, I did just that when I needed new discs at 3K miles on my '04 bike.
:cool:
Yup they should have changed the pads, £25 for a lone bike is a joke.
Still under warranty so had to let them do the sevice, i have run my own garage so am suprised the pads wernt changed, as it normal practice to replace discs and pads together.:cool:
Yes and I meant that I persuaded my BMW dealership into replacing the pads under warranty when they did the discs.
Bristol Motorrad don't charge for a loaner.:augie
The pads should have been changed too.:eek:
The Service price seems about average / verging on the expensive.:confused:
Did you tell the dealer that at the time?
Will you be going back to the dealer brandishing UKGSer replies? Apparently this does work.
Will you be changing them yourself, now?
Aaahh Richard you are obviously a chap gifted with a clairvoyant nature, so please provide me with the lottery numbers. I also noticed that according to the time on your post at 15:17 you will of course know the results before I need to buy my ticket! Or is something wrong with the time on the posts?
ive never had to pay for a loaner from vines when having warrenty work carried out
You're doomed.
:cool:
12k service at Cannons BMW £188.00!!!! 2weeks ago :nenau
12k service at Cannons BMW £188.00!!!! 2weeks ago :nenau[/QUOTE
Please Note this was an anual plus a 12k condition based service valve clearance, oil and filter10/50 fully synthetic, diff and gear box oil + brake fluid changed, throttle bodies balanced, air filter change, reset service indicator Didnt reset the clock tho! :cool:
[QUOTE The Service price seems about average / verging on the expensive.:confused:[/QUOTE]
The Service price seems about average - which is expensive.:augie
Still under warranty so had to let them do the service, i have run my own garage so am surprised the pads weren't changed, as it normal practice to replace discs and pads together.:cool:
Indeed it is normal practice that whenever the discs are changed the pads are... this is shoddy to say the least & bloody dangerous at best.
New pads against disc don't provide barely enough contact area, so the thought of fitting worn pads is something i would expect from an "bodger" and worthy of watchdog...
You should have asked them to provide a brake test report to confirm that the brake performance achieves minimum requirement of road worthiness ... IE the MOT test.
Regards
