Servo removal help
Daviduk
Altrincham
Hi, I am wanting to remove my servo, off an 03 GS. I have seen some good instructions and utube videos but, I am not 100 % confident doing this myself and I am looking for someone who could do this for me.
I am in the Manchester area but can travel ( on resididual brakes ! )
I'm in Manchester area near bury if you needs a lift
Sent from my HTC Wildfire S A510e using Tapatalk 2
Ignore the Utube videos, especially if they're by the american guy.... Far simpler way of removing without any rewiring/cutting needed.
Remove servo unit (just a nuts and bolts job, undo the end piece on the servo unit (4 small bolts), the ECU section. And plug this back into the loom. Secure it to the abs/battery carrier, pull out the abs relay, and remove the lower abs bulb in the instrument panel. Job done.
Just reconnect the brake lines once the metal brake pipes have been removed.
