Servo stuck on ? ? ?
luke scott
Dublin & Andalucia.
Turned off the bike today & when I returned to it later and turned on the ignition the servo pump (whine) came on and the warning light and ABS light flashed. As with my computer I thought turning on & off might work but it didn't help. After a few minutes I tried again and this time I pressed the abs button on the bars. This appears to have sorted it. Have run the bike and all is now in order but any ideas what happened ? :nenau
Not sure if it is an old wives tale, but handguards can sometimes catch on the leavers meaning the servo is on all the time. Might be worth a look.
Thanks Stu. I had checked that straight away. But not that. Any other thoughts guys ? Is the 1150 so old a bike now that there are only 1200 GS riders here on the site ? :rob :rob
1150 riders are probably all in Llagollen, the 1200 riders are safe and sound at home!
Sometimes the front or rear brake lamps switch moves off it's rest and when it does it activates the servos
Is the brake lamp on?
