Should the rear disc be loose?
ER.....NO
You did remember to heat it up first:augie:augie:augie
Some sort of coating on the parts that can be damaged if you bash it off or on cold.
http://www.ukgser.com/forums/showthread.php?t=181453&highlight=rear+disc+flange&page=2
post 32 tells all.
Er.........No i didnt heat it up first..well I did,sort of i used a heat gun for ages and it went a little bit but was well tight.:augie:augie
I didnt want to use anything hotter because I was worried about damageing the seal behind the flange.I had to give it a good walloping to drift it off as well.
I did heat it up in the oven and it went on easy,
Im an inpatient idiot at times and just wanted it done,should have asked advice beforehand me thinks now.:rob
Just hope all that side ways bashing didnt do the final drive bearing:eek::eek:
