Slight oil leak 1100 GS
pedro
Edinburgh, Scotland
Chaps,
I have a slight seepage of oil on the front casing down on the nearside, I've done about 1000 miles since I bought the bike. It doesn't seem to be from the oil level glass as I've had on a previous bike, front crank seal maybe ? I've attached a couple of pics. Your thoughts pleaseImageUploadedByTapatalk1437314093.279170.jpgImageUploadedByTapatalk1437314125.409355.jpgImageUploadedByTapatalk1437314143.284666.jpg
Peter
I think the first thing I would do is remove the bash plate and clean the whole area using Gunk - then monitor it - for days, if neccessary, with the bash plate still off, to see where the oil and dirt starts to appear - sometimes the origin of the leak can be below and/or behind the dirty area - but spreads due to air flow upwards from the front tyre.
Cheers..................Grizzly:beerjug:
I had this on my old GS. Posted on here and the solution (for me anyway) was to simply tighten all the bolts. I was surprised how lose they all were! Instant fix :-)
I would check/tighten and then do as Grizzly suggests
Sent from my SM-N910F using Tapatalk
+1 try tighten bolts 1st , looks like front cover sipping oil , if that won't work you need take front cover off and put new silicon gasket , not difficult but loads dismantling....
