That's it, Proff will never buy one of them now![]()
mileage was about 100,000 when it happened i think
car type ujs last a long time and rarely fail catastrophically but are easy to inspect and often have grease nipples, can we get any lube into the UJs? or are they "sealed for life?"
What are the symptoms of worn UJs? I would imagine extra backlash and probably some vibration, but given Tourance rumble, flip helmet noise and ipod/earplugs,car type ujs last a long time and rarely fail catastrophically but are easy to inspect and often have grease nipples, can we get any lube into the UJs? or are they "sealed for life?"
Picture the scene
Heston services a Honda Cx a couple of hundred people
Me trying to wheelie it
Yes I've seen this before and it's an episode in my life I'd rather forget![]()
The result of UJs being not correctly phased?![]()
thats the one, the snapped shafts iv seen are on drag bikes, same as wheelying![]()
filling the swing arm with caviar couldn't have helped.
It has the later type of shaft with the splines indexed so it can only be inserted in one position.
It has wilber shocks fitted and the ride height is even higher than a standard ADV. Perhaps the articulation was too much for the shaft U/J![]()
) it locked the wheel for a second,and then made the bag of spanners in a tumble dryer sort of noise.It didn't knacker the output shaft,but I had to make a slide hammer to get the remains of the u/j off the output shaft.Couldn't believe how much grief it had been given to be that tight and survive.
Mine snapped a couple of months back, no spline problems etc, just a new shaft and bearings etc. I'd just been doing a bit of light off road and dropped into Frome, going down a back street and that familiar graunching noise erupted from down below and i ground to a halt. Just glad i was bimbling down the road when it happened... high speed???![]()
well, not till tonight anyway
