Speed sensor non ABS Twin Cam
dicktheleg
Pestie to the Nobility
Worcestershire, England
Can anyone tell me where the non ABS GS's pick up their speed signal?
I’m about to fit an E Z Can which can be configured to flash the brake lamp on quick deceleration even when not braking, I think this is sensed off the can bus speed signal.
Just wondering if it will work on my non ABS 2010 Twin Cam, I thought the ABS rings were used to send the speed signal but obviously not on my model.
Rich
not one hidden on the rear bevel?
I'd have thought if they invented a switch that sensed it slowing, is there a G sensor inside ?
not a fan of modern stuff - its a bit like too much roadside furniture - too distracting from what matters
As mentioned. There should be one in rear diff. Wire comes along the drive shaft housing smaller link.
Sent from my M2007J22G using Tapatalk
Speed sensor is the same as the ABS sensor, it's dual purpose. I had intermitted signal previously, causes the speed to bounce.
