Really? Which bit of the damper held the wheel straight? If you had got crossed up on 230kg of bmw then superman wouldnt of saved it even with a damper.
Wonder how many people confuse a bit of front end wobble with a proper tank slapper
No wonder you find yours better with the damper, being a 21014 model its several thousand years down the R&D path bound to be far superior to a simple 2013
I have a Scotts damper on my Husaberg. It is the single most impressive unit I've ever fitted to a bike.
The Scotts damper has three separate circuits - all fully adjustable. They are:
Base damping - The base valve adjusts the amount of resistance you feel as you turn the bars left to right
Sweep damping - These are what control the distance of damping force (or sweep), from the center line out to either side until it releases.
High speed damping - This valving circuit is designed to help absorb large, unexpected hits, such as hidden tree roots or a pot hole. It reacts to spikes that exceed the current base valve setting.
In normal riding, when properly adjusted, I simply don't notice that the damper is there. But 'rim' a pot hole for example and the damper slows steering input and prevents the wobble.
I doubt that BMW have used a Scotts damper and I would also be surprised if the damper they use is as good. But properly adjusted, a damper ought to be a bonus.
MCN view on handing back their test GS - steering damper only fitted to the GS as a part of build consistancy with the production of the new GSA which has one fitted due to differing steering geometry. Not because there is any particular issue with the GS
