xantamisch Active member UKGSer Subscriber Joined Feb 27, 2015 Messages 181 Reaction score 0 Location United Kingdom Nov 17, 2020 #1 I'm pretty sure it's a Zumo 660 mount I need to mount a Nav 5 on a second bike, but thought I'd double check! thanks
casbar Well-known member UKGSer Subscriber Joined Feb 29, 2016 Messages 4,822 Reaction score 1,354 Location Out and about! Nov 17, 2020 #2 xantamisch said: I'm pretty sure it's a Zumo 660 mount I need to mount a Nav 5 on a second bike, but thought I'd double check! thanks Click to expand... Were you going to post a pic of the mount or are you asking if a Nav V will fit a 660 mount? If so, the answer is yes. I use my Nav VI in my car with a 660 mount
PitaNaanRoti Well-known member UKGSer Subscriber Joined Mar 18, 2020 Messages 2,373 Reaction score 2,026 Location Nowhere in particular Nov 17, 2020 #3 Have a 4 button mount to use mine on the CRF
xantamisch Active member UKGSer Subscriber Joined Feb 27, 2015 Messages 181 Reaction score 0 Location United Kingdom Nov 17, 2020 #4 hi yes - checking a nav V will fit in a 660 mount. Realise I'll then need something else to connect the mount to the bike thanks
DC Registered user Joined Mar 29, 2014 Messages 4,185 Reaction score 36 Nov 17, 2020 #5 yep the Nav V will work in a 660 Mount. you can attach the mount using a ram ball type connection https://www.ram-mount.co.uk/combination-brake-clutch-reservoirhandlebar-mount-with-short-length-double-socket-arm-for-the-garmin-zumo-400-660?search=garmin%20660
