sticky downchange
MarkShelley
Very similar to Paolo Maldini
Norfolk, England
My 1100GS has developed an intermittent very stiff downchange , mainly going 5 to 4 or 4 to 3.
Upchange is nice and smooth.
The clutch is adjusted to spec at both end and I have lubed the linkages.
Is this a symptom of something expensive about to happen?:blast
I should add that when I got home tonight I did a gearbox oil change. No lumps of metal evident, just a metallic sludge around the magnetic drain plug.
Lots of threads on here about it and particular bits to clean and lube. One of them was mine! I still get the problem occasionally (I've lubed it twice in the last couple of months) but if I blip the throttle before trying again it frees it up.
