Sundays plan, brake pad change
ELIMINATOR
Hampshire.
'er indoors is taking her grandchildren (oxymoron if ever there was one:augie) out.
I'll be puting in the front brake pads on the 1150, just shy of 36,000 miles isn't bad for the first set is it?
Replaced the back already.
If you don't go fast enough to need the brakes the pads should last indefinately.......:thumb...........:rolleyes: .........:D
Only changed one caliper. The first time I stripped them one of the pads was sticky, this has worn one pad on one caliper. So as loads of meat left on the other I didn't bother.
