The term Static sag normally applies to a static bike i.e. no rider.
You should be looking for about 1/3rd total travel used with rider on board, so 15mm static would hopefully be 35-45mm with rider out of a total 120mm travel typically found on a sportsbike.
On track under 10mm is common, 125gp bikes tend to run at zero sag, supersport / superbikes typically under 10mm, but the road is quite different.
I have also found regardless of theoretical ideals sometimes a bike feels nicer a slightly out of spec, I like a quite sporty setup, but my ZZR14 felt horrible at much under 15mm sag, it was on a relatively soft spring so I expected to wind it down to 10mm, but even at 15mm it felt hard and very high at the rear, I ran a thundercat at 10mm on the road (Ohlins again) and also added some ride height.
Be interested to know what is considered the "correct" static and rider sag for these bikes as a starting point, but I never get too hung up on being "in spec" as what is most important is how it feels to me, the person riding it!
So far I have just added pre-load until it turned nicely without feeling too harsh and put on just enough rebound to stop it wallowing or feeling vague.
A few extra turns pre-load and some more damping and it feels OK two up although the damping adjuster is almost fully in for two-up use.
Would love some Ohlins, or possibly Wilburs if my budget cannot stretch to the Ohlins prices.
