pugster
How you going to compress the spring to change it?
Also do you know the range of 'weights' they offer for front and back on GS.
Believe it or not, the last time I changed a spring on my RGV500 I had a mate sit on the bike to compress the spring and used tie wraps to hold it at that length, took the shock off and the locking ring was loose, hey presto the old spring off. I compressed the new one by lowering my bike lift onto it and zip tied it short and put it on, put the collars in place and cut the ties. Not the most technical way but it worked for me!!
Re the weights, Hyperpro are a progressive spring so they are a generic fit, one spring for all weights. Wilbers do weight specific springs but I went for the Hyperpro ones as they should suit the bike whether I am on my own, two up or touring two up with luggage. Seemed to be the best comprimise for most situations although I am sure others might disaggree with the 'wisdom' of that.
Graham
