SWAROVSKI Binoculars
needlongerlegs
Felixstowe, Suffolk, UK
Me and the Mrs are safari nut-cases, we've seen posh people using :- SWAROVSKI Binoculars
why are they soo good
Any body understand this optical stuff
Is it they are so expensive they most be good type of thingy.
Can anyone one reconmend a basic spec we should be looking for.
G...
Spec !
Apologies if this is too basic but here goes. Binoculars are generally described by two numbers i.e. 8 x 40
The first is the maximum magnification of the eye piece lens, the second is the diameter of the objective lens in mm.
As a general rule any magnification above 10 requires a rest or tripod to use without 'wobble'
The larger the objective the more light enters, so for use in low light conditions bigger is better.
I believe there is also a preferred relationship between the two numbers in that one should be exactly divisble by the other, however this may just be coincidental.
The larger the objective lens, means the larger the unit as a whole.
As a guide, 10 x 50 are generally deemed suitable as good all round binoculars, but are generally larger than pocket size.
As to price, you do get what you pay for in terms of build quality, optical clarity and finish. There are also more exotic things like inert gas fillings which push the price up.
You can spend a little or a lot depending on your circumstances, so the best advice is decide what you want then try them all out.
Hope this helps !
Swarovski are good and are at the low end of the class they are in, the Nikon ED's are equal if not better and not as expensive as Swarovski. The american Leupold & Stevens are also the equal of swarovski.
BUT none hold a candle to Lieca or Zeiss, these two are the dogs dangleys, the image contrast, flatness of field and comfort under long periods of use is beyond compare.
Either one will set you back about a grand or so, I wear glasses and like the chunkiness of the Leica 10x50 BA's and my wife likes her Zeiss 7x42 Dialyt
I also have a Zeiss 30 x 60 mirror scope which is small enough to carry on deer stalking trips and easy to hold with the shooting stick when picking out a particular deer.
Zeiss Riflescopes are much superior to Swarovski scopes and there is not much difference in cost.
So the answer to your question is yes they are good but no they are not worth the cost, for not much more money Leica or Zeiss are better, the cost is in the type of materials used and the time it takes to grind a perfect lens.
When buying binos you need to bear in mind your ability to hold them still, the design of the bino will affect this greatly, the Roof Prism design is the best to hold as the glasses fit naturally in the hand, an 8x magnifcation is good to hold , 10x magnifcation is more difficult.
Binoculars are expessed as 8 x 40, 10 x 50, 7 x 50 etc, the first figure is the magnification, the second is the Object lens diameter 40 or 50 mm etc and this has a direct relationship in light gathering power, the larger the object lens the higher the light gathering power, there is also the exit pupil diameter this is the diameter of the circle of light exiting the eyepiece, and if you are a spectacle wearer this is important, the exit pupil is the object lens dia divided by the magnification so an 8 x 40 bino will have a 5mm exit pupil a 10 x 50 will also have a 5mm exit pupil, a 7 x 20 the small folding types will have a 2.8mm exit pupil, now the exit pupil diameter should be as large as your eye pupil in low light and by coincedence most peoples pupil is 5mm in low light so you will see well into the shadows with a pair of 8 x 40 or 10 x 50.
As magnifcation increases the exit pupil deceases and the ability to hold them still also decreases.
In conclusion then if your pocket can manage a grand or so then Leica or Zeiss, if you can't manage that the Leupold & Stevens or Nikon ED's will be about £700 or a bit less in the UK.
If you travel to the USA then Leupold or Nikon will be half of that but Leica & Zeiss will be nearly the same as UK.
Loads of sites with advice. Bev and I always carry a 'small' pair (fnarr fnarr) when travelling Pentax 10 x I think. Excellent for spec wearers. Cost £199 or so. You pays your money, but to get better read several hundred quid addition. Try loads ! I wouldn't go away without them and the camera
See http://images.google.com/imgres?img...=40&svnum=10&hl=en&lr=&ie=UTF-8&oe=UTF-8&sa=N for quite a choice ! ;)
(think ours are the s/s ones on that listing)
Swarovski is indeed "posh". They are mainly known for their crystal. It's only the name.
Leica and especially Carl Zeiss are best know for their superior quality lenses.
Just to add my twopenneth to the confusion.
I know it’s stating the bleedin obvious, but think about you actually want the binos for.
If you are walking round all day with them slung around your neck, then the new generation of more compact binos are great because they are so light.
On the other hand, if you are hanging out of the top of an old Landie, then weight isn’t a problem.
Also, don’t get fooled into thinking that you need a huge magnification. IMHO you don’t need more that 7x or 8x. If you do need something with greater magnification, go for a spotter scope as well as Jimb does.
The major down side to the compact binos is that they have very poor light gathering power, which means that in low light conditions you wont be able to see a thing, and there is little more frustrating than having tracked down ‘something interesting’ only to raise the binos to see a beautifully magnified silhouette.
If you are still unsure about light gathering power, say you have a pair of 8x40’s, then 40/8= a light gathering factor of 5, which is about the same as your naked eye. 7x50’s have a light gathering factor of just over 7, and it’s phenomenal the difference it makes when it comes to bird or beast identification.
My advice would be to go for the model with the largest object lens that you practically lug about. To give more detailed advice, I would need to know more about how, where, when and why you are using the binos.
I hope that helps.
Cheers Gezzas
Looks like I'm looking for Leupold & Stevens at about 7*50
I want to use them in low light levels mainly from a landy but also for short walking safs
so off to ebay for a bargin
merry crimbo
G
