Posted on here a couple of weeks back, after the final drive would not slide off as the manual said it would sorted that after a request for help on here, thanks guys more advice needed now so here we go.
The uj is stuck on the driveshaft, so continued on to take the swinging arm off, have since stripped the threads on the gearbox casing rh side (heat was applied to pivot studs) repair for this is in hand. But i cant get the drive shft to separate from gearbox output, any advice? Plus when i do achieve this how do i seperate the two parts of the shaft when the shaft is still in one piece inside the swinging arm? Any advice much appreciated, im only getting a few hours at the weekend to work on it hence it is a long winded process in getting things done all this just to replace the swinger bearings, nightmare.
........ good ole bikes the eleven-hundreds
