steve16
I have removed the 2 wire plug sprayed and cleaned but my gear indicator still has a mind of its own and refuses to show me a nice green neutral light.
If anyone has changed their switch could they offer any advice ie
...will lowering the exhaust give me the room I need to remove the top bolt.
...does much of the switch go into casing as this could reduce play when removing it.
...if the above are positive I would estimate it would not take too long ?
Also has anyone had it done at dealers and how much did it cost.
Steve
Steve
