fredkat41
Surge!!!!
Ok,
I have 1150GSA and have dumped the cat for a Remus Y piece. Also I have played with the TPS to the extent it is about .500!!!!! Still a little lunge on throttle closing.
Now for the importnat bit , got the old girl dynoed today and it is running near perfect fueling with throttle wound on
, however on small and half throttle opening it is weak and a massive spike on the air/ fuel mix at 2500 rpm (emmissions regs?).
I have a K & N filter and was thinking of dumping this for the standard to rich up a bit.
To be honest I was going to put the cat back on and reset everything to standard. Now reading this I think it may lean the mix off more!!!
I have got cat code jumper (Steptoe link) and I found this increased the Co2 output to 2.4% from 1.5%.
Okay question: does any one know how all the cat code plugs affect the fuelling?
and: will the cat lean up the mix?
Fred the curious
Ok,
, however on small and half throttle opening it is weak and a massive spike on the air/ fuel mix at 2500 rpm (emmissions regs?).I have a K & N filter and was thinking of dumping this for the standard to rich up a bit.
Fred the curious
