Jiffy176
I've just taken both tbs off to have them refurbed. Whilst taking the cables off the right I noted that in resting position the butterfly wasn't touching the stop.
It appears that previous owners have just tried to balance by adjusting the rh side only as the left was very hard to unlock the adjuster screw was stiff. The rh side had been adjusted up considerably. This seems to explain a lot of things.
My question is when they come back what's the best base setting for the brass screws and the stops. Should there be any play in the throttle cables when properly set up. Logic says there should be slight as long as the cables pull together
I was thinking of turning both stops about 2 turns in to start with both cable adjusters with a little bit of slack, then set the tick over using brass screws. I have a harmonizer. Then balance up tbs from there adjusting cables as need be. Once balanced then adjust stop screws so the spindle rests properly.
Does this sound about right. Anyone give some good advise on installing tbs from scratch?
Thanks all.
Thanks all.
It's difficult to understand your last post
