That doesn't look good :(
jimbo
Looking for a way out
just noticed that all doesn't seem well with my rear drive.
Passesd the MOT fine, but the 7 miles ride back seems to have taken its toll.
The oil seems to be coming out the breaker :confused:
Obviously if you havn't changed/topped up the oil then it is coming from the shaft. Check oil level in driveshaft and if non in there or going down, then there is an oil seal where the driveshaft meets the rear hub ( need a special tool to remove a cast ring to get at the seal though ). Worth checking gearbox level to see if that is going down...although there won't be much difference after only 7 miles !
That's bolloxed.
Is that bigyellags's old bike? If it is I sold him the forks, wheels, bevel box, swinging arm and sub frame.
Wish I'd kept the bits now.
