Thread size
rovert57
WIRRAL
The thread on one of the mounting points on the rocker cover feels like it might give me some problems so could I asl what is the pitch size of the tread ,I know it’s a 6 mm x 20 but the size of the thread is not listed and I was thinking of buying a tap and die set just to clean the thread up in the hole .
Thanks for any info in advance .
So would it be safe to assume that most of the smaller bolts would also be of 1mm pitch.
Thanks for the quick response.
If you can see well enough (!) you can do what i often do - count the distance of ten thread `crests` with an engineers rule and divide by 10.
eg: 10mm - 1.0mm pitch, 12.5mm - 1.25mm pitch etc.
article-308-2-jpg
Hann,s tip is a good one, also the hole size is a good clue specifically for metric threads, this can sometimes help decide if it’s metric fine which some threads are on vehicles. The basic premise of Metric threads is the outer diameter of bolt minus the hole = the pitch. So a 6mm diameter bolt minus a 5mm hole = 1mm pitch.
Metric fine M6 is a 6mm bolt but a drilled hole of 5.2mm because the pitch is 0.75mm.There are charts online to help with metric threads. Imperial a whole box of frogs .
No. That would be an entirely bad assumption. They are not.
The pitch changes with the diameter, and whether it’s coarse or fine or non-preferred.
Measure the diameter with a digital (vernier) caliper, a tenner in Lidl or on Amazon.
For the pitch, Hann has summed it up, but measuring pitches on the actual screw is difficult. Roll the screw on a piece of paper at the edge of a table, and then measure the pitch on the paper, it’s easier.
If you can get to Wigan ( home ) or Burnley ( office ) I have an m6 x 1 tap and a thread gauge. Happy to help.
Dan
Dan
Thanks Dan
I’ve put the guard’s back on and the thread didn’t seem to be binding so I’ll leave it for now but thanks for the offer and information to all on here .
I've had this years; it's good enough for a quick guesstimate;
article-308-2-jpg
I have had this for years; it's good for a quick guide.
If its mothership it wont be std,
it will be something like M6 x20.25 ,,
as they say, close , but no cigar
Why dont you have a look on real oem, they normally list all the thread and pitch stuff
Dan
Deja vu....fekk me Trev, have you still not bought yourself a tap and die set you tight twat. 🙄🤣 I thought you might have done by now after I loaned you one about 15 years ago and which you returned when finished with.
I think he is asking about the two studs in the actual rocker cover that push through the cylinder heads and are affixed with nuts and washers
Which may have been helpful to have had a clearer description :D
Anyway if that is the required thread pitch ? Then it is M6 x 1
Yes Tim ,I remember you loaning me one for the damaged thread on my blackbirds fork .do you still have a blackbird .
Fwiw. Thread size on mirrors is 10 x 1.5 whereas it is 1.25 pitch on almost all other non bmw bikes
