stovesy
I'm finding my way around a new to me GS 1150 Adventure and as part of the fettling I've come to renew a non working idle up (choke) lever.
Having bought it in the summer I've not had a need to start it with the idle lever in use. Taking the idle lever off, it's dead. The metal spring steel and ball bearing are chunks of rust.
I've also taken this opportunity to remove and clean the Bowden cable mixing box etc but have come across an issue.
When refitting the throttle cable back into the assembly, the throttle cable seems too tight. To the point where pulling the idle cable by hand does not affect (turn) the mixing wheel in the assembly.
There is no adjustment on the throttle cable at the handle bar end as it's wound in all the way.
I'd expect that on a closed throttle the mixing wheel is on or close to a stop, and also the slider on the idle up lever should, when pulled affect the mixing wheel slightly. This doesn't happen on my setup.
I can only conclude that the throttle cable is around a 1/4 inch too short !?
I'd appreciate any comments or suggestions.
Thanks in advance for your time.
