I have fitted a throttle lock from Jaws Motorcycles.
It is s very simple mechanical device which replaces the bar end:
Turning the adjuster should apply friction and lock the throttle.
However, even when un turned and backed right off, I cannot turn the throttle!!!
The bar end needs to be tight enough to prevent handgard rotation.
It is advertised as 'a direct replacement for the standard bar end on all the 1200 GS's and the Adventure model'
What am I doing wrong? Anyone else had this problem ? Should I send it back ?
