Time for some fun.. fire up the grinder.
Gundog
Croatia
Picked this up today. Needs modifying.. :green gri
I feel the need for a scrambler...:bounce1
I hope it's a better attempt than the shite jobs of late.
It'll be a hell of a waste of an s otherwise.
If you feel the need, go scramble a wheelbarrow. :roll:
That bike looks too good to chop, loose the shite paint job, go classic black with white pinstripes and enjoy as is.
Paul.
Think you maybe right Rob.. :thumb
Just get it back on the road for now, use it, then see how it progresses.
Made a start last night...
Back brake is fooked.. master cylinder is seized solid and look at the grooves in that disc.. :rolleyes:
The rear master cylinder arrangement is a pain in the arse at best. If your stuck for parts I have a few knocking about in what appears to be good condition. Can't help with a disc but I'm sure I have most other parts.
A good mod is to swap the spindly rear swing arm for the beefier 81-83 item. The only downside is you have to cut the rear brake light switch in half to fit it. Sounds a pain but its bit a bad idea to ditch the standard switch for an hydraulic one if your staying with a disc.
The heavy flywheel s is a lovely quick bike if running properly. You won't wont to be strung out on high bars.
Actually. If that's a deep flange rear disc I have a nearly new cast one in my stash.
What ratio is your final drive?
New Brakes. New springs.
Its gettin there... :)
I was just admiring your flange.... :eek:
:D
Back up and running today... :)
This will do for now.. get it MOT'd and put some miles on it.
:thumb2
