Hi
I'll be swapping out the engine on my 2002 1150 GSA in a month or two. Never done one before, so any advice welcomed. Not so much a step by step guide how to do it the best way (but do feel free to point me to a thread if there is one), more sharing the things you wish you knew when you first did one.
Mine is a 65,000 bike thats had a hard life of late doing a few rallies and green lanes. The outer sheath on the wiring up by the bars is cracking so I'll be having a close look at the wiring but hope a good going to with insulation tape will suffice.
So all I have on my list so far is...
Try and find somewhere with the ability to strap the bike up, to drop the engine out.
New clutch bolts from Sherlocks (they do a kit I believe).
Clutch alignment tool needed.
Its got a new Hall Sensor fitted.
I'll give the replacement engine a full service once in, so will get a set of consumables lined up.
Thats it - pretty short list so far.
Are there any things that I would be crazy to not do while I am going to all this hassle - for example are there bushes or the like that are buggers to get to that don't cost much that I should just do while i am at it?
Advice from the wise much appreciated.
Tnx, Mike F
Tnx, Mike F
