GS 1150 adventure engine swap
nickgarner
London
My GSA has around 135,000 miles on it. The cam chain guide had disintegrated and there is a horrible low-level vibration from the bottom end of the engine. So I bought's a second hand 40,000 mile engine of eBay to do a swap.
On the forums, I'd seen a thread where somebody had set up a DIY gantry, so I copied that idea. The whole project took about 18 hours, with three hours of garage setup, basic prep on the bike. 12 hours doing the actual engine swap and finally three hours of garage tidy up and fiddling around with little bits and pieces on the bike.
The big win was using ratchet straps which made it very easy to adjust everything precisely. Precisely I also lift bought a platform lifter, which allowed me to adjust the engine height during the swap. Thing I did was get a half ton Jack and strap a block onto it, which allowed me to adjust the height of the gearbox and tilt of the engine, which made it much easier to carefully undo everything without the bike collapsing and yanking out various cables.
The gantry was built with storage shelves and a ladder which had around the place, along with a couple of extra blocks on each end so I wouldn't hit my head.
Surprisingly, it was a relatively straightforward job with no major unforeseen issues.
I've created an album here: http://imgur.com/a/RcuYp
That's a good job. :thumby:
I'm surprised it took so little time. I'd have thought it would have taken longer than that. I suppose the time put into setting up the gantry etc, made the rest of the job quicker. You'd lose a lot of time trying to get things to line up if you didn't have a system like that to position things exactly as you needed. I nearly went insane trying to install the engine in my Deauville two years ago because I couldn't get it to line up with the drive-shaft.
Good idea using the ladder & useful pics ! Did you pull the gearbox & shaft & final drive as one unit ?
How's the new engine ?
Fantastic job, enjoy the next 100k
Sent from my HTC One mini 2 using Tapatalk
Superb job :clap. A great way to introduce yourself on your first post. No messing about with 'what oil?' or 'how far can I go on a tank?', straight in with in an engine swop :bow
