tkc's
happy pilgrim
cornwall
what pressure do you run them at on the road on 1200 gsa??
what pressure off road??
do you then pump them up for journey home or just take it steady?
On road 32psi front, up to 36 rear
Offroad around 25 psi, whether, you pump them up for the ride home is up to you, I do.....sometimes
I run 32/36 on and 25/29 off
I'd be interested if you can tell the difference with the lower pressures on road.
I recently rode home in a "spirited" fashion (for me) with 11psi in the rear tyre. It had felt a little vague earlier in the day, in the rain, but when it was dry I didn't notice. I only found out when I put the bike away and noticed a rather large nail sticking out!
Mark
After a leave of absence and spending two weeks on the 650. I found my self stopping on the side of the road to let a little air out of what felt like a vastly over sencitive front end.
When I checked the pressures the next day I found there to be only 16psi in the front :blast I couldn't believe it was that low. Handeling was still very competent for a tyre that looks like a bar of cadbry's dairy milk.
