beemerman
You may recall that i have had a noise that sounded like a dry bearing in the final drive. It started at 300 miles and i havenot had any luck having it sorted. Anyway i mentioned it to the BMW technical guy - Steve, at the motor show in Birmingham last month. He said he would look at the bike next time he was in the area.
He actually made a special trip, took the bike out for a good run, came back & vanished into the workshops. Reappeared after an hour & took off again. when he reappeared he said that there definately had been a noise & they had tracked it down to a faulty rear tyre. They had checked everything including running the bike in gear on the bench & listening with e stethoscope. Eventually they swapped the rear wheel with one off a demo bike & the noise was not there on the road test. As tyres are not covered under the BMW warranty he had to get BMW to agree to replace the tyre. in fact they have done better than this & replaced BOTH tyres with new Metzlers. The bike previously had Michelins. On the ride home the noise was definately not there. I will of course be monitoring it as it did not appear initially until about 300 miles. To say that i am amazed would be an undersatement as i was convinced that it was mechanical. I am delighted not to have the bike taken to pieces, and thumbs up to Steve from BMW & the boys at Mill
