Twixmas Gearbox
Pretty straightforward,get a new front bearing,
Press it on ,measure to front of bearing,remove bearing and cut the recess to the same width as circlip.
We retro fit circlips on any box not already fitted with one.
@mikeyboy Happy to parcel them up and send them to you if you fancy itaking the job on ?
Just in case it helps anyone, I found this diagram of the groove location on the output shaft with some key dimensions..
Just a hobbyist. I have a dull day job and garage time helps keep me sane.
But..I may have my first commission build.
Purely through word of mouth, I’ve been asked if I’d build an airhead based bobber for a guy.
Not my taste at all, but I’m up for the crack.
If it comes off, I’ll start a thread
Here’s an idea, something like this.
instead of this usual hipster shite that turns up here and I end up having to sort out
I’m in agreement with Steptoe.
With Most of the crappy customs we see ,the biggest issues are with the wiring and electrics.
Moto gadget stuff is truly horrible.
This really can be easily solved if original switchgear and lever perches are acceptable.
Simply use a g/s wiring harness,there is nothing more simple.
If something more retro is required,a /5 harness .
Both can be used with minimal cutting/mods.
Thanks for the feedback guys.
My guy is currently looking for a Monolever donor bike (R80 or R100)
I will try and keep him on the path of good taste.
Will post up a new thread when / if the project begins
