urgently need help
ddtwelve
near doncaster
i had an alarm/immobilzer fitted on sat 1/10/16 professional not me , which needed all Tupperware off and tank off all was put back together, now when riding I come off the throttle but the bike is over running up to 2000rpm till I push the throttle back I had a play with the normal top adjusters but it still not snapping back proper ive had a nosey around but cant find pics of cable routing for throttles ive got the cruise control schematic
has anyone got a schematic of the routing of cables I could have so I can get this sorted before I end up in the back of a bus
cheers
What bike is it , some of them have junction box. Your problem could be there also could be something caught between fuel line and back of left throttle body and won't let butterfly to return back ,
Sorry correction right side not left
Val
2 bikes , twice is happy 🤔
Me personally not familiar with newer bikes couldn't afford 😁, but by the looks there is 2 cable system from hand grip to junction box , because tank was removed make sure none cables are jammed and check tension springs on throttle bodies OK and butterfly spring back freely .
Val
Get the guy back who fitted the Alarm to do the job probably...
I would but not getting someone all the way from London area to come up to Yorkshire for. simple thing that I can do
