+Ve Voltage needed !!!
ianran
Here and there
Hi
I need to find a power feed to act as a trigger for a Kliktronic unit when ignition is on.
Anything under seat easy to get to before I run wires all over the place
There is a round junction type box under the seat near where the OBD plug is and there is a switched live that goes into that and easy to joint into
There is a thread or post from Roadrash rider might be under his old name of Roadcraft rider somewhere with pictures from when he did mine
A search may help you out
A search may help you out but i found this
http://www.ukgser.com/forums/showthread.php/410805-PDM60-Ignition-Trigger
Thanks for that but these are for the gs. Tried searching but I must be a muppet but can’t find anything. I will have a play with my multi meter.
