Vertical challenge
Put it on the mainstand. Remove the back wheel first and chock the final drive up on blocks and then remove the front. I used to use an old chopping block but a car jack is fine as well
Thanks for the info, I suspected the mainstand would deal with most issues & the rest was about chocking front & rear appropriately, rear first is good to know, I would probably have started there first for no other reason than it appears to be the easiest to remove.
I thought about doing the same, then I got scared :eek: threw a few tools in my panniers and rode the bike down to the tyre place and did them one at a time, at one point the bike tried to rock back with no rear wheel fitted and I had to hang my jacket on the screen and jam a pannier under the pannier frame to stop it, one thing for sure, it would be a bugger if it came off the stand with no wheels on it :D
Stewart
Stewart
Yes it certainly would!
Mark
Stewart
Mines gonna have more things stuffed under it than can be found in a scrapheap challenge, may fabricate something to bolt onto the rear hub with a lateral bracket onto the garage floor for stability, sort of a peg leg with a big boot.
Did you take it apart so you could get it into your bedroom ?
Not quite, but a good idea.
I have told the kids that when they go to Uni, I will be putting a bike in the room they use for music/homework/computing. French windows off the path will open wide enough, some sheeting on the floor to protect the carpet and Robert's your mother's brother!
That should give me room in the garage for one more.............:D
Mark
Hydraulic bike lift...Machine Mart.
Feckin Awesome...:D
I can park under a big purlin in the garage roof - I'd chock each end up (rear first) and rope each end to the roof too.
Stop being so tight and pay them to do it :aidan
Principles
I'll be happier in the knowledge everything is fitted & tightened correctly also there is the satisfaction element in DIY. I would rather know how to do it just in case I have to in an emergency situation, not to mention so called professionals letting me down in the past with loose bolts etc. non critical but they could have been..................................and I'm tight.
Tight? I notice you are from Yorkshire...that's one of them Scots with all the generosity squezzed out.:P
Also remember to tie the front forks to the stand so it cannot unintentionally fold under the bike. My bike was strangely well balanced when I placed a 15kg sand bag on the back seat while it had no wheels fitted.:D
After removing the front wheel replace the axle spindle in the forks and place either a jack or axle stand underneath it - make sure there is some weight over the front then remove the rear wheel and block it up underneath the rear drive. Easy peasy :comfort
