Wanted lower fork leg
Wrinkly
beverley,england
Slim chance I know, and I've been told they are no longer available.
So, if any has or knows the whereabouts of a right hand (as you sit on the bike) lower fork leg for an 08-09 Stelvio, the early 50mm one. I'd be eternally grateful for a heads up.
Any great ideas for a repair to the wheel spindle Rhino clamp also gratefully accepted.
Bloody Guzzi's :comfort still love em though.
try talking to MG direct , there was a tech notice out years ago , i did get some under warranty . or change the whole front end ?
if its the chrome fork tube Stein dinse have them listed (and in stock ) for 165 Euros
http://www.stein-dinse.biz/eliste/index.php?sid=9d9dgdbcb9agg&lg=en
Thanks Rob, but as Theoneandonly rightly says, it's the whole lower leg I need, or at least the cast alloy spindle holder.
I would look at getting it welded up
You could give these a ring or pop it in to them to see if its possible they are quite local to you.
http://aluminiumfabs.co.uk/
Cheers Steve...After spending days looking, basically all over the world, I couldn't locate a lower fork leg.
So, went along to Craig engineering in Hull, left it with them a couple of days then picked it up. When I picked it up I spoke to John the guy who'd actually done it. He'd cut a large V in the metal then welded it, reamed out the spindle hole and added a sleeve. It's a decent looking job and all for £40, which sounds much better than £673 which was the cost of a new leg. It actually looks much more robust than the original, but time will tell.
I would post some pics, but struggling with photobucket,is there something wrong with it ?
