Warning Lights
john_aero
Glin, Ireland
Ok, so start for start.
you turn ignition ok, all ok, thumb the starter and up she fires, great
hop on and rdrop down into 1st, great
then as move off you usually hear the few cluncks and elec noises as everything goes into place and the abs lights go off and on you go
but today, drop into 1st and off you go, no noise and abs lights flash on and off together. now they go away after while and then the abs warning lights flash but nto together.
so 1st warning is lights flashing both on off together what is this
2nd is abs warning lights flahsing, one on othe roff and vice versa. i was told this is low volt for the batetry.
but it just annoying.
both together is normal before the clunk when you move off ,alternate flashing- abs not working ,try riding a few miles then stopping/restarting the engine (turn off on key) if it sorts its self its probably low volts (batt)
did that
rode for last hour. stopped half way there, and when turnd back on still flashing but i didnt hear a clunk at anypoint as i normally do
did that
try resetting the abs ,if you look around theres a thread to tell you how
cheers will do this.
front sensor looks bit dodgey as it got damaged when had forks off.
may have get new front one
Find someone with a GS911 it should read the ABS fault code and tell you what the problem is.
just plugged my own gs 9-11 in and only abs fault was dash light or something
cleared it and will take it for run later to see if still working
