before you convince yourself you havnt lost coolant,double check the level at the radiator not just the expansion tank.
as others have said,slight emulsification is normal at this time of year.
Quite true of course, but really the system is such that if there is any water loss from the main cooling system that in the header tank will be drawn into the system ...
Never hurts to check though ....
Engine COLD of course
Good head of coolant in the header tank?
Left hand side panel off. Clamp off the hose down from the header tank to the radiator (or the next step will empty it)
Take off the radiator top cap ... It should be full to brimming. Even so, top up until it is full to the very very top, replace the cap, and in doing so will probably displace a little water ... no probs. Make sure the cap is tightened fully!
Any sign if oil in the water? Often, any loss of water in to the oil will cross contaminate ... but not always
Ride and enjoy
Here you see Micky Mod Mk II used for winter running. Whole engine FS365'd then the mod covers up the holes in the front of the sumpguard and the front of the engine is much better protected ... and not as cooled
Also, the neck of the oil tank is long and in the cooling air stream, hence the emulsified oil in there, maybe consider insulating it?
Hope this helps
