WAter pump seal replacement
Tunnel Rat
Basingstoke
About to have a bash at the water pump seal/shaft.
Any top tips (Apart from "Don't go near a Haynes manual")?
Thanks.
Had to do the wife's old bike......all info is out there on chaingang forum..... took me a morning, good chance to service it too.....oil,filter....n coolant. I got away with reusing side casing gasket...but only did coz I forgot to order a new one.
Oil feed pipe is a swine to get casing past, someone off 650 forum got a batch of flexi pipes made up, to replace the ridged one...makes job easier next time.....
More of a fiddle job than technical......go for it :thumb2
Ah, yes, service at the same time......I spotted a drip of coolant on the pump cover just as I was putting the sump guard back on after an oil and filter change. :mooney
DOes the oil return pipe come off completely or just at the bottom end? This is the only bit which isn't clear from the varuios guides.
Think I have some pics on puter at home....will try n post up tonight...:thumb
Oil pipe is to the left in pic, you can move it about to get cover off.....just a bit akward..
re water pump
hi
did mine last summer.
google it on the net & you will find all the info you will need.
good luck & best regards. :beerjug:
p.s. got all my parts to do the job from Rainbow m/c in Rotherham top service. :thumb2
What an arse of a job, or to be more accurate, what a stupid bit of design, where the clutch cover is essentially trapped by an oil pipe which is in turn trapped by the frame.
After a great deal of twiddling, fiddling, fettling, easing, coaxing and loads of other wasted effort trying to get the cover out from behind the oil pipe I did what any sensible engineer does and directed my energy at modifying out the problem by replacing the rigid pipe (and it's rigid approach to doing the job) with a flexible hose (which allows more errr......flexibility)
Flexable oil pipe
Hey all,
Does any one know where I could get a flexable oil pipe to replace the original.. A plug and play version would be the one for me
Hey all,
Got a new one in shed, bought of komatias for wifes bike, but she changed to a twin just after I bought it :augie
40 quid posted
flexable oil line
hi all
anyone else got a flexable oil line to sell.
just thought it would be a good idea to fit one the next time i do the water pump. however the bike has only covered around 3000 miles since last done,no idea when it will want doing again :nenau
many thanks in advance Ronnie. :beerjug:
