John you say Quote (Because I am interested in what others do I tried creating a route using the routing tool which had no destination waypoint but had another via point instead. That route did not transfer correctly, some of the via points were missing and the route reverted to a more direct but less interesting version. When I changed the destination to a waypoint the route transferred intact. Maybe there isn't an answer)
this is the reason i posted a couple of routes up as i was expecting some one to say yes they work perfectly with no missing via points or sorry it doesnt work its got some of the via points missing, Then i would at least get an idea of what works with what. I also realise that you can not test these routes to the full, but you could have tested for the issue of missing via points and that would have helped me, as i do routes for others and i dont want the same issue. and i am pretty certain you could post a route up that gives the issue you are describing without including someones private details this would enable me to actually see if the problem exists for me.
