What can this be ...
thebuyer
Chester, England
Out riding today and got this pop up ... bike feels ok ... any suggestions
2018 GSA 1200
i reckon your Spring Strut Adjustment is faulty.....
Can't be sure though...
Looks like the rear suspension may have lost its reference point, or the ride height rod may be detached (if you look behind the frame by the rear shock on the left side you will see it).
BMW do recommend the suspension is cycled through the full range every 3rd fuel fill up. If you haven’t done it in a while, it would be worth carrying it out.
Rogue error code, had that on my LCD but could only see the error in my GS-911 spoke to BMW and they said, either bring it in and they will clear it, or clear it myself, is what I done, however after clearing it, I done a calibration on the shock, never had code come back since, the code was 480BBC
check it out below
http://bmwfault.codes/
2018 GSA 1200
I had this message as well as a few others when my 1250 wouldn't start.Dealer did what ever they do and not Seen it since.Fuel cap is still opening OK after being replaced by the way :thumb2
my tft had a minor spaz this weekend,something about the traction control been fecked..at about 40 mph on dry a road on the way back from the offy. flashed up twice and hasn't reappeared..gawd knows, should have bought a ktm or whatever you blokes say on here..
Bit of crap or a stone in the rear wheel sensor, happens often, bike will not self destruct. :D
