Gav Active member UKGSer Subscriber Joined Mar 23, 2005 Messages 203 Reaction score 0 Location Glasgow Jun 25, 2008 #1 I'm not beside the bike just now. Does anyone know what size of socket it is for rear wheel removal on 1150? Cheers
Wanderer Registered user Joined Dec 6, 2004 Messages 1,549 Reaction score 0 Location Wandering Jun 25, 2008 #2 From memory you'll need a 17mm socket and a T55 torx (as you also need to move the brake caliper).
Gav Active member UKGSer Subscriber Joined Mar 23, 2005 Messages 203 Reaction score 0 Location Glasgow Jun 25, 2008 #3 Thanks for that, Will.
Possu Registered user Joined Oct 15, 2003 Messages 2,230 Reaction score 1 Location Oxford, England Jun 25, 2008 #4 Both of our 1150's require an 8mm Allen Key to release the rear caliper? Ours are both 2001 bikes, maybe later bikes use Torx? Rear wheel bolts torque to 105nm, Rear caliper bolts torque to 40nm (on ours anyway).
Gav Active member UKGSer Subscriber Joined Mar 23, 2005 Messages 203 Reaction score 0 Location Glasgow Jun 25, 2008 #5 Thanks again.
davegs Well-known member UKGSer Subscriber Joined Jul 18, 2006 Messages 9,264 Reaction score 394 Location bromley Jun 25, 2008 #6 Rear wheel This has to be tight 70ft lbs, or it can come loose I know!!
Gav Active member UKGSer Subscriber Joined Mar 23, 2005 Messages 203 Reaction score 0 Location Glasgow Jun 25, 2008 #7 Am with the bike now and yes, it's a 17mm socket and mine has torx bolts on the caliper. Will bear in mind what you said, Dave. Thanks.
trotsky Registered user Joined Jan 20, 2004 Messages 1,433 Reaction score 0 Location 150 metres from London Jun 27, 2008 #8 Possu said: Both of our 1150's require an 8mm Allen Key to release the rear caliper? Ours are both 2001 bikes, maybe later bikes use Torx? Click to expand... Your bike may have been the happy recipient of a Steptoe Stainless fasteners kit - mine has (most of it) and the torx were replaced with standard 8mm allen heads as part of that.
Aidan1150 Nice but unfortunate husband. Moderator Moderator Joined Nov 17, 2004 Messages 15,081 Reaction score 4,168 Location South Armagh, Ireland Jun 27, 2008 #9 Possu said: Both of our 1150's require an 8mm Allen Key to release the rear caliper? Ours are both 2001 bikes, maybe later bikes use Torx? Rear wheel bolts torque to 105nm, Rear caliper bolts torque to 40nm (on ours anyway). Click to expand... My 2001 GS is the same. Brembo calipers.
