What's the current equivalent of an Autocom Active-7?
markie_wales
Hampshire
Well after probably 10 years or more, I need to replace my trusty Active 7. It's been on 3 or 4 bikes, but just too many bits getting worn now and assume the modern equivalent will be super-smashing-great!
What I am after / like about the Active 7;
- Bike powered
- Small-ish
- Simple. I don't even need a passenger head phone cable as in the 10 or so years of having it, never used the passenger lead.
- Hard wired input for Zumo 660 sound
- Allows me to connect my walkie-talkie / PPT cables.
Also I have had to put a Amplirider in series with the Zumo/Active 7 as I just wasn't getting the volume direct from the Active 7, so if the newer ones putout more volume that'd be great.
Not bothered about BlueTooth and won't be adding a phone to it.
Will probably buy a "kit" as my headset lead is also breaking up.
So what's the current equivalent from our friends at Autocom? Any recommendations for dealers/places to buy?
cheers
Markie
> Try Intaride http://www.intaride.com/
thanks, but for the life of me I can't work out their web site and what I should buy if I want bike-to-bike and have a feed in from my GPS. I have a Motorola T-<something> walkie-talkie with the Autocom connectors, but can't see a cable on that site that would allow me to use it.
cheers
Markie
Give them a call then, they are very helpful and will talk you through all the bits that you need.
UPDATE: So all fitted now. Ended up with an Autocom Logic 1 kit with the addition of a 12v power supply and a plug in lead to link to the walkie talkie. I also discovered that my old red box suppressor was knackered (when fitted to the Logic) so brought a part 4004 which is a 1.5/2m 3.5mm audio lead with the suppressor built in (and much smaller than the old red box).
All tested and lovely in the garage, out for a ride with my lad on pillion over the weekend to check the volume at speed is OK. If not I'll put my Amplirider back into the system.
cheers
Markie
UPDATED UPDATE: Volume is much better with the Logic 1 than the old Active 7. Lad on back and I could hear the music fine so no need for the Amlirider with the Logic 1 - which makes the whole set up much neater / cleaner. Just the Logic 1 box and the 4004 lead with built in suppressor - much better than the Active 7, a stock 3.5mm jack lead, red suppressor box and an Amplirider.
cheers
Markie
